Solved by KMercier_C3D. Go to Solution.
There were two classes specifically about Subassembly Composer at Autodesk University 2011:
http://au.autodesk.com/?nd=class&session_id=9196 and http://au.autodesk.com/?nd=class&session_id=9212.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
There were two classes at AU last year on this, one by myself and a very detailed class by Kati Mercier that you should check out. We both did an hour of how to get started with Subassembly Composer.
We also have a number of sample Subassemblies on the Help Wiki site that you could look at for starting points.
Cheers,
Peter Funk
