Civil 3D Forum
Subassembly Composer - Omit Points & Links when Zero Depth Set?
2 REPLIES 2
RDunkley
438 Views, 2 Replies
I am working on a Lane with several layers of Pavement, Base, Sub Base etc. At times, the user may wish to omit one or more of the layers.
I am wondering what would be the best way to have SAC omit the Points, Links & Shapes of a Pavement Layer when the Depth Variable is set to Zero?
Regards.
Ross.
Currently using Civil 3D 2022
2 REPLIES 2
mathewkol
in reply to: RDunkley
That would be pretty easily done with a decision branch.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
mathewkol
To elaborate, check if the value is non-zero and add the layer, or don't. Your workflow will still end up going to the same place.
Matt Kolberg
Rail Community
