Attached is a shoulder/aggregate subassembly.
I have this the way I need it except for one thing. Superelevation - Yes/No
How do I modify this to have an input parameter for "Use Superelevation Slope" - "Yes or No"
(I get errors in the event viewer for no superelevation defined when using this in the state it is in)
Thanks.
Solved by xquilax. Go to Solution.
I've attached the solution
Leonardo
IF((Side=Left)AND(SE.HasLeftSO),SE.LeftSO,SuperSlopeTop)
Leonardo,
Thanks for the reply and help.
I am having to revisit this subassembly.
Everything works well except I can't change the grade of the shoulder when I am not using superelevation.
How can I easily add that functionality?
See Attached.
Thanks.
Attached is new zip file...
This was created in SAC 2014
hello
you must add decsition bifore use superelevation and add input parameter use super elevation yes/no . after thes decsition you will use supere elevation or just use parameters , sory for my bad english put see atachment you will understand
whedzisi,
Tanks for looking into it.
I will give it a try...
