Employee
peterfunkautodesk
Message 11 of 46 (5,660 Views)
Re: Subassembly Composer - Ditch Depth in Fill Condition
02-04-2013 12:40 PM in reply to: KMercier_C3D
What if you went up first for the backslope (using slope and Delta Y) and then do a Aux point to the surface. Then from that daylight point, go down for the ditch bottom and then back up to the hinge point.
In the sketch AL1 is 6:1, AL2 is what every slope you want for the foreslope, AP2 is the daylight, P2 is the ditch bottom where L2 is at 6:1, and L1 is at the foreslope. P2 is 1' below P3.
Peter Funk
Peter Funk
*Pro
fcernst
Message 12 of 46 (5,641 Views)
02-04-2013 01:42 PM in reply to: peterfunkautodesk
Very clever!  Thank you for showing...
Fred Ernst, PE
C3D 2015 SP2
Ernst Engineering
www.ernstengineering.com
jblackwood
Message 13 of 46 (5,637 Views)
02-04-2013 02:23 PM in reply to: peterfunkautodesk
Brilliant!
Never thought about pulling about my geometry book and looking at similar triangles!
New Member
premj
Message 14 of 46 (5,612 Views)
02-05-2013 12:07 PM in reply to: peterfunkautodesk
FYI
Many similar tips & tricks are covered in my SAC training book and for details feel free to visit:
http://www.solidcad.ca/training/civil/autocad-civil-3d-subassembly-composer/
PJ
jefferyheinrich3734
Message 15 of 46 (5,268 Views)
11-21-2013 09:51 AM in reply to: peterfunkautodesk
So how wuold I set this up to be a condtional situation where in cut I want a ditch to be 18" deep from the edge of shoulder and in fill to have a ditch at the toe as described.
Employee
peterfunkautodesk
Message 16 of 46 (5,255 Views)
11-21-2013 10:22 AM in reply to: jefferyheinrich3734
You would check to see if the P1 point is above or below the target surface and then branch the SA for cut/fill. In the cut branch, you would create the ditch down 18" at your slope, and they daylight up to the surface. In the Fill, you would use the method described above.
Cheers,
Peter Funk
Peter Funk
jefferyheinrich3734
Message 17 of 46 (5,248 Views)
11-21-2013 10:32 AM in reply to: jefferyheinrich3734
Ok.  So I am completely new to SA composer how would this look in the composer?
jefferyheinrich3734
Message 18 of 46 (5,221 Views)
11-22-2013 05:10 AM in reply to: jefferyheinrich3734
OK.  I think I have the subassebly created in SA composer, but the preview is only displaying the false condition (cut).  Is there a way to display the true condition (fill) so I can check the input?
doni49
Message 19 of 46 (5,219 Views)
11-22-2013 05:19 AM in reply to: jefferyheinrich3734
On the Target parameters tab, set the surface's Preview Value to a negative number.
EDIT:  After posting this, I thought maybe it would be helpful to explain that a little further.  The "surface" that the preview displays is flat and is shown as though it's at this "Preview" elevation.  If you have an end condition that is dependent upon being a specific distance above or below the surface, then change this preview value such that you're able to see what happens at the various elevation changes.
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Customization
Other Helpful links:
My File is too large to post or I can't post it due to privacy issues!
jefferyheinrich3734
Message 20 of 46 (5,216 Views)
11-22-2013 05:23 AM in reply to: doni49
Thanks, but I must not have something correct because it still only displays the false condition (cut).
