Civil 3D Forum
Subassembly Composer Crash on deleting Parameter - TEST!
4 REPLIES 4
ceethreedee.com
905 Views, 4 Replies
Maybe i am going crazy. Can someone please try this and confirm
Civil 3D 2014 - Subassembly Composer
  1. Open Subassembly Composer
  2. Create one Parameter
  3. Rename it to "links" and change it to "string type"
  4. Give it a default value
  5. Try and Delete the Parameter.
  6. Does application freeze and become unresponsive?? I have tried on 5 computers in my office all of them freeze!
thanks
Kapanther
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
4 REPLIES 4
JonVinci
in reply to: ceethreedee.com
Yes, this happens to me too. No idea what's going on.
magnus.svensson
in reply to: JonVinci
Same here in SAC2013, it happend a week ago, also a spooky grid in flowshart after copy or delete objects, guess a windows update has messed things up.
doni49
in reply to: magnus.svensson
Before you attempt to delete the parameter save the file & exit SAC.  When you repoen, you'll be able to delete it.
I know it's not a fix but it'll at least allow you to delete it as needed.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
J_Koedijk
in reply to: doni49
To add onto doni49's workaround;
As long as you haven't changed the name of any Input/Output Parameters you can delete a parameter. But if you rename any parameter you can't delete any parameter (this work session) without freezing up the system.
For example you add a new parameter: "parameter11" and change it to a Double, give it a default value of 3,00. Now you can still decide to delete it without freezing up the system. But as soon as you change the name, it will freeze. The same will happen if you change any of your other parameters names of trying to delete parameters.
Rail Community
