New Member
robpretus7735
Message 1 of 6 (5,534 Views)
Subassembly Composer 2014
5534 Views, 5 Replies
06-19-2013 09:39 AM
How do you install subassembly composer for 2014?  I can't seem to find it as a download.  I also restrted installation of Infrastructure Suite 2014 to see if I can add it and it was not an available choice.
A little rant: why is everything so hidden with this software?
LisaPohlmeyer
Message 2 of 6 (5,520 Views)
Re: Subassembly Composer 2014
06-19-2013 10:44 AM in reply to: robpretus7735
When I created my deployment, it was listed as an optional subcomponent from within the AutoCAD Civil 3D 2014 installation wizard.  It's still a separate program.
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
neilyj
Message 3 of 6 (5,484 Views)
06-20-2013 04:55 AM in reply to: robpretus7735
In IDSP 2014 when the splash screen appears with all the programs to install, Civil 3D has to be expanded to allow selection of the SAC
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
jmayo
Message 4 of 6 (5,274 Views)
08-15-2013 02:00 PM in reply to: neilyj
Hmm, I don't see ant option for SAC. I have the SSA, Express, geo... No SAC?
Do you really have it listed in 2014 IDSP? Do you have an admin image?
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
troma
Message 5 of 6 (5,254 Views)
08-16-2013 10:43 AM in reply to: jmayo
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Where-is-the-subassembly-composer/m-p/4367853#M211783
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Member
chuckl
Message 6 of 6 (3,326 Views)
01-20-2014 01:07 PM in reply to: robpretus7735
I had the same problem.  You will need to re-install it from the flashdrive.  I have since included it in the network deployment.  However, I didn't see it when I initially installed the IDSP.  When you re-run the installation, answer all the questions as if you were doing an initial installation, then it will give you a list of all the application and they will be marked "installed".  Find Civil 3D and click the drop-down to expand Civil 3D and check the box.
Yes, it is there, and yes, it is buried under several layers of...what can we call it, organization?
Chuck Litchfield
AKS Engineering and Forestry, LLC
C3D 2012 SP4.0, C3D 2014 SP1
