Civil 3D Forum
Subassembly Composer 2013 - Change order of input/output parameter
3 REPLIES 3
1197 Views, 3 Replies
Hi!
Is there a better an easier way to change the order of input/output parameters in the subassembly that i've created in SAC 2013 than the one where you have to go into a XML-file in the PKT archive file?
I've created my subassembly and I want to control the order of parameters to have a flow similar to the actual workflow.
Thanks in advance
/Tommy
3 REPLIES 3
civilgz
I have the same problem. Hope Autodesk can upgrade that. Something like "Move Up", "Move Down" would be helpful.
dnietubicz
I agree with needing a better way to re-order parameters. How is it that you edit the order in the xml file? This would be better than nothing. Doug
in reply to: dnietubicz
Rail Community
