Civil 3D Forum
Subassembly Composer 2012-shape
4 REPLIES 4
KPMV
463 Views, 4 Replies
can't create shape S4,S7,S8
rename extension .jpg to .pkt
4 REPLIES 4
KMercier_C3D
in reply to: KPMV
If you delete the flow chart arrow after S4 you will be limited to seeing only the links created up to that point in the flow chart. It does not appear that you have a closed shape in which to define S4 and you also can't have a portion of a link define the shape. Therefore to create S4 you need to do two things prior to S4:
1) Create a link from P6 to P18
2) Create a link between P13 and P16 (Currently L13 goes from P12 to P13, you could split this into two links of P12 to P16 and P16 to P13 or have P16 to P13 overlap P12 to P13)
Once you do these two things you should be able to create S4.
I am guessing you have similar issues with S7 and S8.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
KPMV
in reply to: KMercier_C3D
still not working, reporting that shape s4 is not closed
KMercier_C3D
in reply to: KPMV
Repost your modified file.
Pronouns: She/Her
KPMV
working with different name of shape.
Thank you.
Rail Community
