Trying to create a conditional lane outside super subassembly using the 2012 subassembly composer.
In my previous post the process was not working due to an invalid decision.
The attempted decsion was: LeftOutsideLane>=0#
I guess the subassembly cannot produce a result in layout mode because the slope has not been determined.
So I have now used both left and right supers to draw auxiliary points using: Slope and Delta X
Then set the decsion on the difference in Y.
It's still not working though. The resulting connected subassembly is being created at any slope.
Any help would be greatly appreciated...
Solved by rodney.page. Go to Solution.
Your case has been escalated to Autodesk Product Support and we are currently looking into your issue and will get back to you in due course. Thank you for your patience.
You have to use the right API call for the super elevation:
SE.RightLO and SE.LeftLO
The on-line API has the syntax in it.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
