When creating a sub assembly from a polyline, I would like to use a simple code set style for which links and points are automatically set to "datum"
If I edit the code set style standard for exemplle, I do not see how to do that.
Thanks for support
MHB
I believe it is impossible. You have to do it manually each time. However I do not use this command, but if you go to your drawing settings->subassembly->commands-> right click on CreateSubFromPline and press edit command settings you will be able to edit all the defaults there. However I did not find this feature to edit.
Thanks for your comments. I did go already to Default styles in CreateSubFromPline and I tried to edit Code Set Style standard but there I am stuck. I don't know where I could set the links and point codes to datum only.
As I have to create many new subassemblies for different kind of irrigation canal shapes, it would be so usefull not to have to set the codes to each point (for the link, we can select the option of creating the subassembly with only one link, so it is not to cumbersome)
Br, MHB
As I said, I don't think it's possible to edit this feature. Why you are not using subassemblies from palletes or create your custom subassembly with subassembly composer?
As you have already been told this is not possible by creating a subassemly from a polyline.
You have to manually set each Hook position, point, link and shape code for each new assembly.
You have three options really.
The choice is yours.
M.
Thanks to both of you for your advices. It least I know that what I wanted to do is not possible.
I will explore option 3 as suggested.
Suggestion (if autodesk programmers are reading us): maybe this possibility to preset the code style could be further added in the future versions ?
BR,
MHB
