Afternoon All,
I am running a corridor in Civil 3D 2012 that has two baselines. I have read past postings regarding issues with multiple baselines in section views, but understand this problem was eliminated in 2012? In any case, this does not seem to by my issue. Attached you will find a section view through the two baselines (one is for a general overlay, the second for widening). The section view seems to display correctly at station 3+75, but 25' feet further down the road it does not display the corridor assemblies correctly (as can be seen by the lack of a ditch and shoulder overlay in the second image).
I have checked the code styles to make sure all links are included, as well as the comparing section view properties. All settings and styles appear to be the same, and the corridor seems to be built correctly. If I sample the Finished Grade corridor surface, it displays in section view as if the ditch were there (see third image).
Does anyone have any ideas or have you seen this before? Any insight is greatly appreciated.
GKG
