I have a ditch and a road that need to follow separate profiles but be integrated with each other as a single corridor and the ditch's 3:1 slope needs to meet up with the road's 2% slope. Is it possible to have the two subassembiles target each other without having to create a dummy surface or a feature line for targeting to? Attached is a snapshot of the road and ditch configuration.
Solved by sboon. Go to Solution.
My ditch will be at a grade of ~0.15% with periodic drop structures at 10% to correct for changes in elevation, while the road is to be a minimum of ~1.2m above original ground, wouldn't the DaylightBasin subassembly adjust its horizontal location to meet the elevation target and introduce jogs?
If you wanted to maintain the 3/1 ditch foreslope and the 2% shoulder slope, and allow the intersection point to move as the ditch profile changes then LinkSlopesBetweenPoints may be appropriate. In this case the ditch width parameter would be zero. Set a marked point at the edge of the lane then attach the sub to the inside edge of your ditch.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Jay, I need to maintain the 3:1 slope for the ditch and 2% for the road.
Steve, that sounds like what I'm looking for. Will try it out this afternoon.
LinkSlopesBetweenPoints solved my problem, and a bit of searching led to a descriptive post and sample drawing on AUGI's forum.
http://forums.augi.com/showthread.php?131725-Help-with-assembly-problem
Thanks Steve, much appreciated!
