As I've mentioned before, I'm new to modeling in Civil 3d and am trying to convince my Terramodel using coworkers that this is the way to go. With that being said, I'm still having a little trouble figuring things out. I can't seem to find subassemblies that do exactly what I need them to. For instance, I need a shoulder that has the base and sub-base extending past the rest of the pavement layers. Is there somewhere I can go for help that might clear this up for me?
On a side note, my boss (Terramodel user) is used to having a cross section editor that has a table beside each section showing the offsets and elevations. I've told him that I think the only way to get that is with a section report. Is this correct?
Thanks in advance!
Desirea
FBL & Associates
Hello Desirea,
On question 1, take a look at ShoulderMultiSurface. This allows differing width for pavement and earthen shoulder layers.
Regarding question 2, you can turn on Parameter Editor while in the Section Editor. This works best with two monitors.
Tim
Thanks! I will check out that subassembly.
On the parameter editor, it doesn't seem to show what he is used to seeing which is the offset and the elevation on his design surface and then he can switch to subgrade surface and see the offset & elevation on that, too.
I also need a subassembly that is similar to the Basic Lane Transition but that has the pavement / base thicknesses. I need it to allow me to target a profile & alignment like the Basic Lane Transition does.
Use LaneOutsideSuper. You don't need superelevation for this to be a useful subassembly.
@dbussie wrote:Thanks! I will check out that subassembly.
Sorry, I gave you an reply that doesn't directly answer your question. The parameter editor will provide some of the information you're asking for, things like design widths, slopes, daylight elevations.
In order to see elevations at specific design and datum points, you would use Code Set Styles. If you set it up so that one code set style shows labels for Top and another shows Datum, you could switch between them while in the Section Editor (Section View Options, at the bottom.) This would not show the data in a table, but it would be very readable nonetheless. You can label any points the engineer wants to see with many different data properties, including offset and elevation.
Thank you! I will look into setting up a code set style that will provide him the information tha he is looking for.
Since you were so helpful with the other assembly, I was wondering if you could tell me one that will have the pavement thicknesses but will allow me to transition by targeting a profile or alignment.
LaneOutsideSuper can target an alignment for width and a profile for cross slope. In the "Help" under "Subassembly Reference" there is a page for each OTB subassembly. In those pages you can find behavior descriptions, target parameters and code diagrams that will be very helpful after you get accustomed to reading them.
I should have added that polylines, 3d polylines, survey figures and feature lines can also be used for targets.
