I've created a subassembly in SAC 2014 and have imported to my tool pallette but when I try to add to my drawing I get .NET classes error.
Any ideas or solutions?
neilyj (No connection with Autodesk other than using the products in the real world)
HI Neil. If you post your pkt file, I'll try opening it here and see what happens.
What I've currently got installed here is pretty much OOTB C3D. We're transitioning from 2012 to 2014 and the boss is working on porting the customizations over. He hasn't done any of that on my machine -- but installed it so I could "get used to any changes made in 2014".
Don Ireland
Engineering Design Technician
My bet is you don't have .NET 4.5 installed on your machine. Although C3D 2014 only required 4.0, an update to SAC made it where you have to 4.5 installed to use SAC SAs.
Thanks for the replies - I just opened it up in SAC and saved as new file and then added to tool pallette and I was able to use the assembly
