Hi I am just starting to use corridors and grading groups. I made an assembly and want to create a dynamic feature line of the outer most left limit. However when I try to create the feature lines only the crown, top of curb and back of curb are available to use as a feature line. How do I set other parts of the assembly as targets? It won't create a corridor surface of the left side beyond the sidewalk?
Please see attached.
If anyone knows a good training video to watch on this it would be appreciated.
Solved by Jeff_M. Go to Solution.
Which subassembly did you place there? If it is one that targets a surface (LinkSlopetoSurface or one of the daylight SAs for example) then you set the surfaces that each SA should target under the corridor properties.
The top button in this image will set allow you to set the targets for the entire corridor. The second one (and subsequent ones) will allow you to set the targets per region (I only have one region in this example).
Don Ireland
Engineering Design Technician
Thx for the starting point. I will start researching it.
Do you know how to set the outside boulevard width to a feature line? It allows me to set the others but not the outside boulevard.
Attached.
1/ Properties tab
2/ Corridor surface showing surface only going to edge of sidewalk and not outside boulevard. (contours in yellow, property line or end of outside boulevard in green. The contours should go to the property line, green line).
3/ Corridor surface feautre lines
I haven't used that SA. But if it permits you to a feature to target a featureline or alignment then it'll be in that same "Target" dialog box.
If the SA allows the INSIDE to target a FL or Alignment, then I'd be surprised if it doesn't allow the outside to do so as well.
Don Ireland
Does the generic subassembly.UrbanSidewalk not have a point code already defined at the location? I acutally did a search neither Urban nor Basic Sidewalk subassemblies have codes at those points.
So is it safe to say some of these assemblies don't have point codes at some locations?
I have only been able to surface up to the back of sidewalks and not the back of boulevard/property line. I have to build a grading group to grade from back of sidewalk to back of boulevard/property line, even though the boulevard is present in my assembly. Am I doing this right?
I attached the help file (see attached). In it it shows the coding diagram and a table which explains which codes have points. Does this mean P4 in the attached file does not have a code. Is this correct? And if so is there a way to a add a code to P4?
That is correct. As I mentioned, add a Marked Point to that location and you will then get a featureline created at the outer boulevard location.
Don Ireland
Use the UrbanSidewalk subassembly from the Curbs tab of the Imperial or Metric subassembly collection.
I was only addressing how to set an outside boulevard width and assumed he would use your suggestion to place a marked point there so he could create the feature line.
Thx. Just learning these assemblies and corridors. It's a little overwhelming. Appreciate the help.
Thx for your help.
