Civil 3D Forum
Sub Assembly Composer Help
3 REPLIES 3
jaianth
6796 Views, 3 Replies
Dear all,
I had installed Sub assembly composer compatible for 2012, but i couldn't find its shortcut or exe to open it. It appears in Add/Remove Programs and regedit. But no installation folder is present in Autodesk within Program File. Also I tried to search my entire hard disk to find the exe file but couldn't find. Any help is deeply appreciated.
Jayanth
Jayanth M
India-Highway Design engineer
AutoCAD Civil 3d 2012
i5-2.7 Ghz, Windows 7 Professional
4GB RAM.
3 REPLIES 3
Karsten.Saenger
in reply to: jaianth
The default installation path for the subassembly composer is
"C:\Program Files (x86)\Autodesk\Subassembly Composer 2012"
Search for "SubassemblyComposer.exe" if you need to search on your local harddrive.
If it is not there it might be deleted without uninstalling.
Karsten Saenger
jaianth
in reply to: Karsten.Saenger
Examined both cases but couldn't find. But its not uninstalled it shows in add/remove programs of control panel. Please let me know the solution for it.
Jayanth
Jayanth M
4GB RAM.
Karsten.Saenger
As mentioned it might have been deleted without uninstalling. Then it is still listed in the add/remove list of the control panel.
Try to un-install it and then re-install it.
If it does not work give Microsoft Fix It a try: http://support.microsoft.com/mats/Program_Install_and_Uninstall
Karsten Saenger
Rail Community
