Dear all,
I had installed Sub assembly composer compatible for 2012, but i couldn't find its shortcut or exe to open it. It appears in Add/Remove Programs and regedit. But no installation folder is present in Autodesk within Program File. Also I tried to search my entire hard disk to find the exe file but couldn't find. Any help is deeply appreciated.
Jayanth
Solved by Karsten.Saenger. Go to Solution.
The default installation path for the subassembly composer is
"C:\Program Files (x86)\Autodesk\Subassembly Composer 2012"
Search for "SubassemblyComposer.exe" if you need to search on your local harddrive.
If it is not there it might be deleted without uninstalling.
Examined both cases but couldn't find. But its not uninstalled it shows in add/remove programs of control panel. Please let me know the solution for it.
Jayanth
As mentioned it might have been deleted without uninstalling. Then it is still listed in the add/remove list of the control panel.
Try to un-install it and then re-install it.
If it does not work give Microsoft Fix It a try: http://support.microsoft.com/mats/Program_Install_and_Uninstall
