I have created a new sub assembly using the composer, but when I add it to an assembly in Civils and re-run the corridor with a new surface, the corridor doesn't recognise the sub assembly and the surface does not include the profile.
I pretty new to sub assembler composer so must have missed something out but can't see what, and the help files are next to useless!!
Thanks in advance.
(I've attached the .pkt file for reference,)
Solved by KMercier_C3D. Go to Solution.
You need some link codes in order to generate a surface from your subassemby. (for example L2, L3, and L4 should all be "Top").
On the "Input/Output Parameters" tab you will also want to define your Side as Right. (so that you can have the mirror image using the same subassembly when you need it on the left.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Kati is too modest to direct you here, but if you need more information on how to add point, link and shape codes and format them so that they work properly then you need to check it out.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Sorry Guys,
Still struggling here to understand what codes go where and where "Top" and "left" and "right" go!
Any chance you could fill in the codes on my original attachement to see where I'm going wrong?
On Links L2, L3, and L4, in the Properties panel add "Top" (with the quotes) to where it says Codes under the Link category.
At the bottom right hand side there are a bunch of tabs, one of them says "Input/Output Parameters". There is a default parameter called Side, set the Default Value to this parameter from None to Right.
Pronouns: She/Her
Brilliant thanks.
I didn't realiase the input/output tab parameter default was a default and added another and that's why it didn't work!
