Civil 3D Forum
Sub assemblies have moved to 0,0,0
5 REPLIES 5
rsBria
608 Views, 5 Replies
I am having a nightmarish problem with sub assemblies.
I have a drawing that contains seven assemblies. Suddenly all the sub assemblies for all seven assemblies have moved to 0,0,0. Has anyone experienced this before?
I am running Civil 3D 2008
Windows xp with sp3 installed
Thanks for any help
5 REPLIES 5
AlmasSuljevic
in reply to: rsBria
Any chance these assemblies are referenced from other drawing? Can you upload your drawing(s) for us to look at?
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
in reply to: rsBria
Sorry to bring up an old topic, but this has happened a few times to me now.
From time to time, without warning, all of a sudden some of my subassemblies detach themselves from the assembly marker and move themselves to 0,0,0.
I am not sure whats triggering it, but it is a right pain as the only solution seems to be to reattach each subassembly back to its marker on by one. (Moving them all together spreads them out even further).
Any suggestions on this?
Are there any suggestions for this problem? I am experiencing this with a recent drawing in 2016. I have a few more assemblies than the other person posted.
Autodesk just doesn't seem to care or be able to fix these long term bugs.
Can you please check whether the moved sub assemblies are in "unassigned Subassemblies" (In Prospector tab-Assemblies-Unassigned Subassemblies)? If there you have to reassign them to your assembly.
Reddy
No they are assigned. If i look at the Assembly construction of each it clearly shows they are still part of the build. A friend of mine seems to think it is a registry error.
Rail Community
