Civil 3D Forum
Styles
2 REPLIES 2
474 Views, 2 Replies
Styles
Once Styles are made in a drawing what is the process to utilize them in a seperate drawing or move them to your drawing template?
2 REPLIES 2
open your template file and drag the new style into it.
Reid
AlmasSuljevic
I agree with Reid, that would be the easiest way, although time consuming in case you need to import more. But just in case if you were not aware of new commands that will let you import Styles and Settings and the same time, please see AECCIMPORTSTYLESANDSETTINGS and AECCIMPORTSTYLES.
There are other ways to do it globally see following post: http://beingcivil.typepad.com/my_weblog/2009/08/export-styles-from-drawing-to-drawing.html
I hope this helps.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Rail Community
