I've been modifying a template and just noticed something. If I hover over the style on the settings tab in the toolspace it gives me the information about the style including the correct Modified by and Date Modified. If I select the style the information in the lower pane is does not give me the correct information for Modified By and Date.
I though this might be because I hadn't saved the drawing. I saved and it didn't change. So I went to a style I would have modified a couple of weeks ago. It showed the right info when I hovered over it but did not show the correct information in the lower pane.
Is there any way to get that information to update?
Allen
Civil 3D 2012 sp 2.1
Allen Jessup
CAD Manager - Designer
I just notice that the problem occurs only while listing the styles one at a time. If I select the collection and display all the styles in that collection the Modified By and Date are correct.
Allen
Allen Jessup
I opened the drawing at work and see the same thing. Hover over a style and the information is correct, select the whole style set and the individual styles listed in the lower pane is correct, select a single style and the information in the lower pane is incorrect.
I don't know where the program is getting the old information from. Why would this be stored in a different place than the rest.
Allen
Allen Jessup
When I select a single style I don't get any info at all, the whole portion is greyed out. When I select the whole set or hover over a single style I get correct data (AFAICT).
Mark Green
Working on Civil 3D in Canada
