In addition to those already mentioned:
1) Ability to do a "quick audit" between multiple drawings. For example, compare all styles in the current drawing to those in the template, and let me know which ones are different.
2) After doing the above, a quick way to select styles in the current drawing to add to the template, or replace the existing version in the template.
3) A way to change the parent/child relationships of styles - i.e., a way to take a child style and make it a top-level style, or take a top-level style and make it a child of another existing style.
4) A way to "reset" values in child styles so that they are once again like the parent. For example, I have a style with text size 0.10". I create a child, but I set the child text size to 0.06". Now if I change the parent to 0.08", the child will remain at 0.06". We need a way to "reset" the child, so that it will once again change with the parent. Ideally, we would have a "same as parent" option for ALL settings in Styles, so we can easily tell when the child is getting the value from the parent, and when it isn't.
This is just a quick-n-dirty list. Styles are so weak right now that there is TONS of room for improvement.
Sinc
