Can a expresion be use for text anchor point or Attachement?
I looking at using the ML or MR based on if the distance is Plus or Minus.
Solved by BrianHailey. Go to Solution.
Hi Robert<
I am not sure what your question is, could you please give more details on what you would like to accomplish?
Thank you,
Unfortunately, the only thing an expression will return is a number. You can use that number in the X and Y offset to adjust the label but you can change the attachment point using an expression. I've longed for the time that an expression would return a string or even a boolean but alas, currently it only returns a number.
I want to have a Label, with two component, I have an expression to rotate the text (perper to mirror), and I have the text to plan read, the problem is the two componet, are in the wrong place.
With plan read off, the text is in the wrong place. My options it to have style for each options/angle, but since I'm using reference text, ever time I change the stye, the reference text goes to none. Plus this take time.
I going to look at using the x y offset, but I'm not sure If I can calc the length of the text.
Thanks for the idea.
Maybe if you show us an image of what you would like to do, we could give you some ideas.
Not exactly sure what you are trying (as Tatiana suggests, perhaps an image would help us). Also, check out the "Flip Anchors with Text" option. Perhaps that will help you get what you want.
