I am trying to make a dynamic block with the rotate function and I am having no luck.
I have the attributes locked.
When moving the rotate grip the angle changes but the text does not rotate.
I am stumped.
rossco
If you want to rotate the text, I think your block definition is correct.
Use BATTMAN command to update the existing block references or insert a new one and try to rotate that block.
Also you are in the wrong forum section ,there is a forum dealing with Dynamic block
