I data referenced a network from a base file into a drawing with profile views, where I labeled everything. I xref'd that drawing into another drawing to setup viewports. All the structures are shrinking. Any idea why?
Of course I'll get a million comments on why or haven't I heard of just data referencing into my viewports drawing, but please don't respond with this comment. It doesn't help me a single bit. Thanks!
I solved this by manually resetting the sump depths on all my structures. It's the first time this has happened. I believe it the error might be due to the fact that I selected all my structures and set the sump depths using the "properties" option, simply because this is the first time I've done this, and the first time I've got this type of error.
