My structures are set to a surface and looks good. But when I raise the pipe past a certain invert elevation my structure pops of the
ground. I set to NORULE for all pipes and structures but it still pops out of the ground. My adjusted rim is zero
Thanks in advance
What structure are you using? Some structures have a minimum height above the top of the pipe.
For example, if you are using a conic manhole, the pipe can't enter the structure within the cone so the cone will always be above the top of the pipe.
Yep, this is why we had to make our own parts. The variable that is causing this is "Minimum Vertical Clearance". The default structures all have something set. We created new parts (which we were going to do anyways) and set the "Minimum Vertical Clearance" to 0.
