Valued Contributor
myerpryor
Message 1 of 5 (314 Views)
Structures not plotting with publish
314 Views, 4 Replies
08-26-2010 05:32 AM
My storm drain profiles will not plot the structures if I publish. They plot ok if I use the plot command, but I'd like to be able to publish. Has anyone run into this?
Active Member
SWGDrafting
Message 2 of 5 (231 Views)
Re: Structures not plotting with publish
02-22-2011 01:15 PM in reply to: myerpryor
i lose my profile when publishing my sanitary sewer profile sheets..
Active Contributor
envirocad
Message 3 of 5 (151 Views)
01-17-2012 09:33 AM in reply to: myerpryor
I have this problem with a few drawings also. They will plot to PDF individually using the DWG to PDF.pc3, but if i PUBLISH the existing grade in the profile is missing.
Civil 3D 2011
Windows 7 64bit
12GB RAM
glacoste
Message 4 of 5 (115 Views)
11-21-2012 07:08 AM in reply to: myerpryor
Has anyone found the reason or solution for these problems. I've been having a similar issue with my data referenced surface profile not plotting using publish.
Now my surface profile will not appear unless I synchronize every time I open the contract drawing. I have tried recovering all drawings.
Gerry Lacoste,
Civil 3d 2012 sp2
mathewk
Message 5 of 5 (109 Views)
11-21-2012 07:51 AM in reply to: myerpryor
Turn off publish in background and try again. This can be found in OPTIONS in the plot/publish tab.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
