Civil 3D Forum
Structures not plotting with publish
4 REPLIES 4
mpryor433
666 Views, 4 Replies
My storm drain profiles will not plot the structures if I publish. They plot ok if I use the plot command, but I'd like to be able to publish. Has anyone run into this?
4 REPLIES 4
in reply to: mpryor433
i lose my profile when publishing my sanitary sewer profile sheets..
I have this problem with a few drawings also. They will plot to PDF individually using the DWG to PDF.pc3, but if i PUBLISH the existing grade in the profile is missing.
glacoste
Has anyone found the reason or solution for these problems. I've been having a similar issue with my data referenced surface profile not plotting using publish.
Now my surface profile will not appear unless I synchronize every time I open the contract drawing. I have tried recovering all drawings.
Gerry Lacoste,
Civil 3d 2012 sp2
mathewkol
Turn off publish in background and try again. This can be found in OPTIONS in the plot/publish tab.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Rail Community
