I'm working in Civil 3D 2013 currently. I have a Civil 3D "template" DWG that has all my current styles in it. My ACAD.DWT is a blank drawing with no styles in it, but has all the same drawing settings. When I copy in a structure style (using drag & drop from toolspace) from the C3D template to a new drawing (acad.dwt), the size of the block in the style changes.
This is from the C3D template:
This is from the acad.dwt:
Anyone know the reason for this? Like I said, ALL the settings are the same.
Solved by gccdaemon. Go to Solution.
Your screenshots show inches on one and feet on the other dwg for the P-FH block.
I suspect somehow there's an insert units or drawing units issue causing this scaling issue of the P-FH block when copied from dwg A to dwg B.
That's just it, I've checked everything and there are no variances (except frame values). I used express tools System Variable Editor and exported the SVF Files and compared them using notepad ++. Here they are for reference.
Hmm, Does entering -DWGUNITS @ command line from each dwg return the same units?
Both the same there too. I'll try turning off the scale on insert.
Command: -dwgunits
Drawing units:
1. Inches
2. Feet
3. Millimeters
4. Centimeters
5. Decimeters
6. Meters
Unit for length <2>:
Drawing unit display formats:
1. Scientific
2. Decimal
Linear display format <2>:
Linear display precision <4>:
Scale objects from other drawings upon insert? [Yes/No] <Yes>:
Match INSUNITS to drawing units? [Yes/No] <No>:
Another thought, what happens if you import it using the Import Styles tool rather than drag/drop?
Showing feet instead of inches with that method. Any idea where the setting is for that? Must be a Civil 3D setting, but the units and zones data matches.
Sorry I don't know either where it's grabbing these settings from, just had a hunch it might behave differently.
I found the culprit!
Toolspace->Settings Tab->Right click on drawing and select Drawing Settings->Ambient Settings tab->Dimension property->Unit
