Civil 3D Forum
Structure reference alignment not holding information! HELP PLEASE!
0 REPLIES 0
Message 1 of 1
187 Views, 0 Replies
I'm using Civil3D 2015 and I’ve created a rather large pipe network.  I've cut all my sheets and noticed that one section of storm structures are referencing the wrong alignment.  So I went back into my base file, and modified the structures to see the correct alignment. All is good in the base file. Then I go to my sheets (where the pipe network is data referenced) and they still see the old alignment, even after syncing.
So then I went thru in my sheet and modified the structures that were incorrect (using the prospector) and changed them that way. This worked. Great, saved it, closed it, all is good.
Open the sheet again and it all reverts back to the wrong alignment!! But just in the sheets, the base file keeps the correct info. What am I doing wrong??
0 REPLIES 0
Rail Community
