Civil 3D Forum
Structure Profile Label Issue
6 REPLIES 6
158 Views, 6 Replies
C3D 2006, Win XP Pro SP2
I'm having a problem with the way structure labels are coming into my
profile view.  I have one that comes in correctly, I have three others that
don't.  They are all the same style.
This one came in correctly.
+[img src="@80535"]
The Other 3 did this?  Why?  Same Lable Style entirely.
[img src="@80542"]
6 REPLIES 6
Did you label the structure more than once?
There is a bug that causes label issues when there are more than one labels
associated with a structure or pipe.
Matt Kolberg
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
that don't.  They are all the same style.
+[img src="@80535"]
The Other 3 did this?  Why?  Sam e Lable Style entirely.
[img src="@80542"]
Only one label per structure.  Would this
issue apply if a label was added, deleted, then
readded?
I've been able to make labels work after I delete
all labels associated with a structure.  Then readded.
once?  There is a bug that causes label issues when there are more than
one labels associated with a structure or pipe.
readded?
For a manhole structure in profile view, what does the label use as it's
insertion point. The insert elevation (rim) or middle of manhole?
You should be able to set that under "Feature Settings" in the Pipe Network
styles. Look for "Default profile label placement for structures" there is
one that says "Structure label placement". However these, don't always work
properly even if this is the first label you've applied to a structure.
This is a known issue.
"Ron Mills" wrote in message
news:4851528@discussion.autodesk.com...
"Matt Kolberg" wrote in message
news:4851998@discussion.autodesk.com...
That was it, problem solved. Thank you!
Rail Community
