Hey Guys, Alright I created a Storm drain Pipe Network and none of the existing object style blocks will work to correctly represent the proposed storm drain top that I'm required to use. So I'm hoping to get some direction into how to add a new block that will show up in Object Styles to choose from. Thanks in advance for your help.
dherb.
1. Make a structure style that assigns your desired block in plan and profile if required.
2. Add a new part to your part list that has this style assigned.
3. Edit network and Add structure to plan or Swap Part.
John Mayo
In your Feature Settings, you set the structure style that you want to use to be the default.
You draw the structure however you want and then define it as an AutoCAD block. If you aren't familiar with how to create a block in AutoCAD, you can search on Google or watch this video I found by searching on Google: http://www.youtube.com/watch?v=zsrkcbv1Ys8
