Civil 3D 2012. One structure in my pipe network is not following along when the network is data-referenced in to other plan drawings. The structure is present in the source drawing, and included in the network, along with the pipes that are connected to it. All other structures and pipes are operating fine. A sychronization does not fix the problem.
What gives? Has anyone seen this or dealt with it??
Todd
No, haven't seen it. Are you sure it isn't there? Are you looking in the drawing space or in the prospector?
Mark Green
Working on Civil 3D in Canada
Thank you both. Yes the part is present, both in the drawing itself and in the toolspace, but only in the source drawing. I checked the network properties and found that there was one structure listed as an "undefined Part type" in the Statistics tab. This one was the culprit, and after removing the part and bringing a new one in and reconnecting the pipes, it seems to be working.
Not sure how the program mistook the part for being undefined.
