Reseructing a thread from eight years ago . . ..
But surely there is a better option now?
The full structure label is important elsewhere, but a label showing only the structure number would be preferable on plans only.
A solution anyone?
When you create a new structure, the structure is typically named 'Structure (x)' and the description is pulled from the parts catalog. We go into the structure properties and rename the struture (under the 'Information' tab) to fit our naming convention. The only important thing here is that each name be unique. And, we also fill in the Description to show the structure type that fits our design, ie 'Curb Inlet' or 'Grate Inlet'. Once these are set, the labels become easy.
Have you tried changing the Structure Name Template in your company's dwt?
Settings tab of prospector, expand pipe networks, expand commads, right click on Create Network. Expand Default Name Template and just leave the counter in the Name field.
John Mayo
