Using C3D 2014, along with a continuously growing list of bugs...
Every so often after a regen, open, switching spaces, or plotting, my plan structure labels move. I'll move them back but it will happen again in the next couple hours.
What gives... it this another bug? Should I look into a workaround?
So i've noticed that even though the dragged state is set to "as composed", if i drag my label a certain distance away from the structure, the leader grips eventually show up. I believe this is what is causing the problem because of different orientations in viewports for each label.
I never had this issue in 2012 using the same dwt.
If anybody can shed some light, that would be great.
FYI - locking the layers seems to help but it's not a preferred solution as it slows down production.
