Suppose you have an existing structure that you are going to tie into with a proposed pipe.
We label existing structures with smaller text and a different color (as opposed to proposed labels)
Is there any way to label the structure where the one single proposed pipe text is a larger text size with a different color, as shown here?
It's doable, but not realistic because you'd have to have a dozen or more styles for one profile. You could also go through and set a bunch of expressions which is also a headache. The easiest way to handle this is to try the "EDITLABELTEXT" command and modify your basic label individually. You can always reset the label as well by selecting it and right clicking.
Create mtext with the 2nd formatting. Then try to carry the formatting through a copy/paste into the label style editor from the mtext.
John Mayo
