I have a plot drawing that xrefs a drawing containing pipes drawn in profile. Everything is fine in the drawing containing the profiles. In the plot draing containing the XREF the label structures extend to zero.
I was able to fix some of them by setting the Default Profile Label Placement to "Graph View Top" this only got some of them though.
I am running 2014 SP2, although an SP1 machine has the same issue.
I have been doing pipes like this for years and this is the first time I have run across this issue.
Conan Witzel
GICE Inc.
Austin Tx
Hi Conan,
I have been trying to recreate this behavior with no luck as of yet. Is this happening to random structures, or is there a certain structure this is happening to?
Would you be willing to upload your drawings so we could take a look?
Hi Conan,
I am gald to hear that this was just an isolated instance to that one drawing. As using a new drawing has resolved this issue, it could just be that your other file became corrupt.
Hopefully this will not happen again, however if it does, please post here and let us know.
