In the case of a pipe network structure, where one pipe is circular (say 60") and the other pipe is box (say 5'x4'), how can you get the "connected pipes" label to reflect [size in feet X size in feet] for the box pipe and [size in inches] for the circular pipe?
An expression maybe? But I don't see how you can conditionally affect a portion of the "connected pipes" label since it's one label object.
Solved by Cadguru42. Go to Solution.
What do you mean by "connected pipes label? are you labeling the Pipes or the pipe types as part of struc label?
When I label the Pipes with a Pipe style usinng "material name" it wants to show them both as a diameter value.
If I apply 2 separate pipe styles I get the attached. The label on the right is using "Inner Pipe Width" x "Inner Pipe Height".
So if labeling in a structure style it doesn't appear possible because of the difference in the way it looks at the "material name" values both as dia.
This.
I don't know about material name, but you could form an IF statement to check the "cross sectional shape" (Circular vs. Rectangular) and then build the label based on that.
If circular, then <size>"
If rectangular, then <width>' x <height>'
The problem is that "connected pipes" is only defined once to create a label for each connected pipes, with no opportunity to modify the individual strings with an expression.
I see.
Have you tried adding a "Text for Each" component to your structure label style?
This will expand the available options to be used in the label.
Oops. My earlier screenshot was incorrect.
The existing style we are using *is* using a "Text for Each" component.
But the problem I described still remains.
The label is built using a single "Text for Each" component and defined (in our case) for curcular pipe:
(for example: <flowline> <circular pipe size>" - <pipe direction>)
...and that label string applies to all connected pipes. There is no way to conditionally change the label based on pipe shape.
So for a [5'x4'] box, the label simply says [60"]
Wow. It's hard to believe this isn't a problem for more people.
Hasn't anyone else used pipe networks with circular and rectangular pipes at the same structure?
@rkmcswain wrote:Wow. It's hard to believe this isn't a problem for more people.
I actually just created an existing pipe network where a 6' x 3' box culvert turns into a 48" RCP, but we don't know exactly where it changes or how, so I've just got a null structure where we guess it changes. I've got issues with box culverts and incoming pipes that I posted just a few minutes ago. Not quite the same, but similar because I need a round pipe to dump into a large square pipe, but with no structure.
I'm not seeing any way to label the pipe types per connected pipe within the structure labels when the pipe types vary.
We don't label the pipe type or diameter/size at the structure, only on the pipe.
Mark Green
Working on Civil 3D in Canada
If there are more than two pipes connected to a structure, how do you know what the inverts are for each pipe? Do you label each pipe in plan view with inverts from both ends? Seems like that would make a very large label, especially if the pipe is a short one.
Inverts we do label at the structure. Either at the bottom of the profile view, or if there is no profile view for a smaller job, then listed out in plan view next to the structure.
That doesn't change the fact that we only show the pipe size on the pipe.
Mark Green
Or the fact that the inverts and direction will still label ok when connected pipes involve various part types such as box vs. round.
The issue is when trying to show more than one connected pipe type within a structure label.
We don't label pipe size / type at structure either just on the pipes.
Jay, engertech, R.K.
I'm sorry, I didn't mean to be argumentative. I probably shouldn't have bothered posting since I had nothing helpful to say. I was only answering the question "Hasn't anyone else used pipe networks with circular and rectangular pipes at the same structure?" The answer is that they likely have, but possibly haven't run into this issue due to differing labeling requirements. That was in no way intended to diminish the importance of this issue, since clearly many people do need to label in the way you are attempting.
Mark Green
troma - no problem. I understand exactly what you are saying, and it sounds like you understand the dilemma here.
I should have posted this image from the get go - to make it easier to understand the desired output.
So if you only label the invert elevation at the structure, and you have multiple pipes at that structure, how is someone reading the plans able to determine which elevation goes with which pipe, and what size they are (specifically for crossing pipes, where you only see the ellipse)?
We show the direction, similar to you. N, S, E, W.
[Little side note: If a pipe direction is not exactly North, C3D will still label it as N, up to a certain tolerance. Then it will label as NW or NE. Does anyone know how to adjust that tolerance, so more pipes will be simply N or W, and avoid the NW designation?]
We assume that the contractor can look at the plan portion to see the pipe size, can look at the adjoining plan/profile drawing for more information (PVC/concrete etc.) and can mentally connect the northern pipe to the invert labeled 'N', the westerly pipe to the invert labeled 'W' etc. Is that too much to assume?
Mark Green
Well, I'm not going to judge. We put 'useless' information on drawings too, like the specified diameter of Water Valve (clue: it's the same as the watermain that it's on!). But the less the better, so far as I'm concerned. Less for us to worry about updating, anyway!
Mark Green
@GZE wrote:
My work around is to insert pipe description in label style to distinguish circular and rectangular pipes
I don't understand what you mean.
There is only one entry (text for each), which creates a text label for each connected pipe.
So that label can only be defined once.
No matter what you insert as part of the label, it will be used on ALL pipes at that structure.
I think the point is to use the Description rather than the Diameter in the label.
Then you just have to ensure that all your descriptions are right!
Mark Green
