When labeling structures (& pipes) in a network, the labeling is defaulting to the default label style set up in the Feature Setting under Pipe Network. For example, when I go to label a stucture in a profile I select the structure and go to Add Labels...select Single Part Profile. I want the structure to use a certain label style for that part & not the default style set up in the Feature Setting. Where do I go to make this happen? This was working before but now it's not (I'm sure). I'm using 2015 Civil 3D.
I guess it depends on how you are labeling.
If you are selecting and right clicking or have it set to auto label:
If you are using the Annotation Tool:
Try changing the Command Setting here:
Settings Tab Toolspace > Pipe Network > Commands > AddNetworkPartProfLabel > Default Styles > Structure Profile Label Style.
