Hi everyone!
I would like to know if it is possible to display the pipe inlet/outlet elevation in my structure label. It seems like it is not possible...
It is possible to use the inlet/outlet elevation of the pipe in my pipe label however I would like to display it in my structure.
All the best!
Mikkel
Solved by rkmcswain. Go to Solution.
Yes, you need to use a "text for each" component, as described here.
