Civil 3D Forum
Structure Label Border Frustration
6 REPLIES 6
jporter
850 Views, 6 Replies
So here’s my dilemma. . . I’ve got a structure label which labels the manhole rim elevation and the connected pipe information (see the attached image-01).
I realize that I can go into the label style and turn on the border for each component, but I want one box surrounding all my components.  In other label styles this isn’t much of an issue, however in this one I cannot move my “Text for Each” components into the “Stucture Text” component (see the attached image-02)
Is there a way to either combine all my components into one or have the label generate a box around everything?  Take a look at my attached image-03 to get an idea of what I want.
Any input is greatly appreciated.
Thank you in advance,
Jason
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
6 REPLIES 6
ToddRogers-WPM
in reply to: jporter
Use a Block...
Todd Rogers
jporter
in reply to: ToddRogers-WPM
Mr. Rogers,
I owe you lunch next time I see you.  I guess all my "thinking outside the box" limited me.  I should have thought of the box.  That was it.
Jason
Jason Porter
www.asti.com
ToddRogers-WPM
No problem Jason!
Todd Rogers
mhvam06
I know this thread is old but I have a follow-up question.
Is it possible to make the block dynamic?
For instance I have a label that registers inlets. That means if the structure has 2 inlets it will have 2 lines. 3 inlets 3 lines etc.
However the block is the same size, right? How would you handle this?
Kind regards
Mikkel
mhvam06
in reply to: mhvam06
I'm thinking about adding a line (block) being attached to each "component name".
The component at the top will have a horizontal line attached above and 2 vertical lines to either side.
Next component will have 2 vertical lines to either side.
Bottom component will have a horizontal line below and 2 vertical lines to either side.
The above solution would solve my issue... it's not very "intelligent"/intuitive though.
mhvam06
Lines are not being added with multiple inlets.
I'm out of ideas.
Rail Community
