Is there a way to edit the floor thickness of structures?
I tried to edit a structure and changed the floor thickness to 0, but it wouldnt show up in the network layout tools.
Also I cannot find manholes at all in my parts list. Do they come with the factory parts list?
The parts list are stored in your drawing which would inherit the list from the dwt file you use. The NCS ...dwt file have a bunch of preloaded parts. I don't know how to edit the floor - sounds lke parts builder , yikes!
Joe Bouza
Joe is right, you will need to edit the floor thickness in Part Builder:
FTh is value you will want to edit.
Hope this helps!
Also for a basic tutorial on how to add/edit sizes, please see this blog post I wrote on the subject: http://beingcivil.typepad.com/my_weblog/2009/12/part-builder-how-to-add-custom-part-sizes.html
Thanks Seth. I remembered reading that blog in the past but forgot where it was. Do you have any suggestions on further examples/ readings? The PB has been a big hurdle for me, not that have have a need for elaborate structures or pipes but there are a few things I'd like to be able to do.
Also, in 2008 I point to our server for the network catalog which seem to me to be appropriate for sharing. I'm still testing 2010 and my catalog pointer goes to.. C:\Documents and Settings\All Users\Application Data\Autodesk\C3D 2010\enu\Pipes Catalog\ and I get an "earlier version" warning when I try to edit a part as your blog describes. This will not harm my 2008 parts, right?
Joe Bouza
Joe Bouza
Hi Joe-
Glad you are making use of my blog post. I wrote a few others regarding a few different aspects of Part Builder:
http://beingcivil.typepad.com/my_weblog/2010/07/assigning-optional-properties-to-a-part-size.html
http://beingcivil.typepad.com/my_weblog/2011/03/runtime-part-parameter-configuration-error.html
Other than that you may want to go through the tutorials found within Civil 3D.
Hi DSM_dude-
I can't reproduce this. I set the FTh to 0.000" in Part Builder, added that to my Parts List and drew a pipe network with connected pipes. The structure properties report 0.000" floor thickness:
Even with rules applied I can still have the FTh "stick" to 0.000".
I've got some images to show the problem I'm having.
I am editing the "rim to sump height" so the bottom of the structure matches my inverts. This is something the Engineer wants. Upon editing the height on a few structures, I notice that the floor thickness will suddenly appear.
I have had no trouble modifying part sizes in previous versions of Civil 3d but we recently installed 2012. I am able to open the part builder and change sizes and even able to validate the changes but when I try to save I get a message that the drawing is read only and it can't save. Any Suggestions?
Thanks!
Hi jer7rob-
Try selecting the Civil 3D 2012 icon>right click>run as administrator. I have seen this happen on Windows 7 machines even if you already have full admin rights.
Hope this helps!
That worked! Thanks! This is the first time I have been using Win 7 and tried to do it. Now if I could just figure out how to eliminate the 2.0' sump depth default. Any ideas on that one?
Glad to help!
The sump depth can be set via your structure rules. However it still may appear that you have a sump depth if viewing in profile view and this is due to the FTh (floor thickness) of the structure. The FTh can be changed in Part Builder to whatever you would like it to be. If you don't read our blog, I have written a post describing this very process that should be posted in the next week or so. Please keep an eye out as it may be helpful: Being Civil
I did get the "Set Sump Height" rule set up. Thanks again!
One question I have is why have a default of 2.0'? Is that a standard somewhere as a water quality feature for storm sewers?
Unfortunately I am not sure what Development bases their default sizes on of the top of my head. These sizes are easily editable in Part Builder, and if you take a look on the first page of this thread I have linked the blog posts I have written on this subject.
Thanks again!
