style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
"danefuller1577" wrote in messageAUTODESK
href="news:6195011@discussion.autodesk.com">news:6195011@discussion.autodesk.com...
PLZ FIX! I have the problem of Pipe Structure Alignment Override references
changing back to the original as well. It's now SP2.1 of Civil 3D
2009.
Resurrecting an old thread because it is still a major shortcoming in the Plan Production process. I've seen a number of posts regarding this over the years, but evidently not enough to warrant a change in how C3D functions. I still see no reason why the structure's reference alignment can be overriden but that override applies ONLY to the session in which the drawing is open....once the drawing is saved and closed the override gets reset. What's the point of allowing the override in the first place if it won't get saved?
Does anyone have a fix for this yet? I am having problems getting stationing to stay after closing drawing. I'm using Civil 3d 2021
Had the same issue with reference surface - not reference alignment- with a specific drawing.
Every time I would open the drawing the reference surface of some structures woul be set to "none" despite having set it to a certain surface before the last Save.
Solved it with fixing the errors after running the AUDIT command.
Sometimes AUDIT could provide good help for issues that only happen with a specific drawing.
