Civil 3D Forum
street alignments with a "not so" parallel bikeway/trail
5 REPLIES 5
MKH-VB
324 Views, 5 Replies
I am in the process of creating a road, which is a rebuild of an existing road, but during the rebuild, the client wants a bikeway path that is approximately 5-8 feet away, but doesn't run exactly parallel to the road. It will have more twists and bends in it. How would a guy go about creating an assembly for something like this? Do I have to create 2 separate alignments? Just wondering how the workflow would go on this? Any help will be greatly appreciated.
MKH
mkh
5 REPLIES 5
rkmcswain
in reply to: MKH-VB
In general, you will need some sort of alignment for the bike path, whether it's a true alignment or a feature line, then you "tie" this path to a point in your assembly.
Someone will be along shortly to correct me, add more detail, or both.... 🙂
awood
in reply to: MKH-VB
In addition to RK's advice you would create an Offset Assembly that would target the alignment/profile/featureline of the meandering path...
Kind of like in the screen grab below...
HTH
AWood
rkmcswain
in reply to: awood
Thanks @awood - as I was writing that, it started to dawn on me that it's been a L O N G time since I had to do one of those and I realized I wasn't much help.
awood
in reply to: rkmcswain
 Well you had step #1 correct anyway 🙂
sboon
in reply to: MKH-VB
Four possible ways that I can think of.
  • One assembly with a generic link and some targets to step across the gap from the road edge to the pathway.  All of the sections will be perpendicular to the main alignment.  This may mean that they're skewed, relative to the pathway edges so curbs and daylighting can be a problem.
  • One assembly with an offset assembly included.  At each section of the main alignment you will get another section perpendicular to the secondary path alignment.  You will need a design profile and possibly superelevation parameters for the path.  Since the offset sections are not perpendicular to the main alignment you may have difficulty using the section view/editor.  The sections will also be at random stations on the pathway alignment.
  • Two assemblies and two baselines in one corridor.  Similar issues as the previous scenario, but you should have more success with the view/edit tools.
  • Two assemblies and two corridors.  Also similar to above, but you will have to produce two corridor surfaces.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Rail Community
