Anyone ever seen a mystery site like this?
This alignment and the others in this drawing were created on <None> site.
C3D 2013 SP2
Using 2014 now.
I opened a new, clean drawing using a clean template.
Created a feature line, and everything is normal, no crazy names.
Then I started a new drawing, using our "infected" 2013 template. Just opened it, nothing else
Then I switch back to the new 2014 (previously clean) drawing, and now the feature line is "infected" with the crazy long name.
So apparently, it not only infects drawings opened in the same session *after* an infected drawing is open, but all currently open drawings too.
At this rate, every working drawing in the house will be infected soon.
Any updates on this issue? I started a clean new template from the blank ACAD.dwt and it started out ok, but now even brand new styles from scratch are having the **error**. We are also seeing naming issues with objects as well. I thought I saw a post somewhere that this is confirmed in 2013, 14, and 15!!!?
Ron C.
Wow RK. You are right that it won't take long until everything is infected.
Lots of fun...........or not.
Ron C.
It's only a matter of time now before everything is corrupted with this naming thing. Drawing by drawing. How would you even figure out what has been corrupted/infected and which haven't? And how would you go about fixing it even if you knew?
IMO - we have to wait on Autodesk to ID the culprit, and then provide a fix to (a) stop it from happening, and (b) stop it from spreading to other drawings.
Seems a lot like the DGN linetype bloat problem, except that only spread when you did a copy/paste, not just by opening an infected drawing.
We were discussing this earlier today in the office and I mentioned that I wonder if it has anything to do with a Windows update?
Seems that alot of users are reporting that they noticed this starting around the same time frame. Just a thought.
Ron C.
I hear that RK. I am not convinced that it is just a display issue or, as Autodesk stated in their reply to you, that it is benign.
With what I am seeing with the aecc objects, I think it is more than that.
Ron C.
I just noticed this in one of my drawings as well (Civil 3D 2013, SP1). Feature lines that were not previously named at all now have the strange names. The names do not display in the Prospector table of the feature lines, only in the Properties.
This is a fairly small drawing with less than 50 feature lines, so i renamed them all, closed the drawing and reopened it. The names i assigned to the feature lines held. However for drawing with more feature lines, or other affected objects, this may be too tedious.
I am now getting reports that this is definately not benign. I had a user tell me that after the **error** showed up in a curve label, the data of the label changed to ???. Benign behavior? I definately don't think so now.
Ron C.
Now propagating to layer names via site names for me.
John Mayo
We are starting to experience this issue on our office.
Any word from Autodesk on a solution??
Nothing newer than what I posted in reply #12, which is essentially the same reply for most problems submitted. Autodesk does not like to say when or if something will be fixed, published, available, etc.
This is DEFINATELY not a beign error. I just modifyied a tag label that had lost its link due to the anchor error and now I have ??? in my table for the bearing and 0.00' for the distance.
This needs to be fixed across the board, right now.
Using C3D13, The only version that works for Surveying purposes, since ADESK can't fix the Survey Figure Properties Bug they keep breaking.
Rick Jackson
Survey CAD Technician VI
