This one realy takes the cake. The command worked so it didn't affect my work at the time. But working in 2012:
TRIM Current settings: Projection=UCS, Edge=None Select cutting edges ... Select objects or <select all>: 1 found
Select objects: Select object to trim or shift-select to extend or [Fence/Crossing/Project/Edge/eRase/Undo]: c
Specify first corner: Specify opposite corner: 䵘䱆䉉㨠㜠䤠癮污摩洠獥慳敧渠浵敢㔸㐺 ᅈ߾Couldn't find the message 4 in msg database 85 䵘䱆䉉㨠㜠䤠癮污摩洠獥慳敧渠浵敢㔸㌺ Couldn't find the message 3 in msg database 85
Allen Jessup
Civil 3D 2012 SP 3 / IDSP 2014
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
Allen Jessup
CAD Manager - Designer
Mark Green
Working on Civil 3D in Canada
