I have some imported points and a polyline created with those.
When i try to rotate the pline around a poit it seems that some edges are locked?
Even if I copy this pline in an empty area alone and try to rotate it again i get the same resulsts.i tried the move comand with a vertex as a base and the same reults.
I do not know where the edges are locked .
Can someone please help?
What is going on?
Thanks!
I don't understand the question because plines don't have edges. Perhaps the pline has some geometric constraints applied? Can you copy the object to a new drawing and attach the drawing here?
