Is there a way to straighten a curved parcel segment? IOW Turn the curve in to a straight line.
I thought I has seen this coverd here before. But I can't find it.
Allen Jessup
Civil 3D 2012 SP 2.1
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
Allen Jessup
CAD Manager - Designer
I don't think there is a way. I exploded the parcel to a polyline, used the mid-arc grip to turn the curve to a line segment and recreated the parcel from the polyline. No too difficult, but it would be nice if parcels had the same mid-arc grip.
Allen Jessup
Allen Jessup
I have found this issue as well, in fact I recently stopped creating parcels with polylines and create them from single segments, the advantage to this is that the segments remain single entites but you can still lable all of them at once. if you need to delete a specific segment you just delete it and add a new one in. Seems to make things a little easier IMO.
Rick Jackson
Survey CAD Technician VI
Interesting. Do you still get an area label?
Allen
Allen Jessup
Rick Jackson
Allen, most of the feature line editing tools on the Modify tab of the Ribbon can be used with Parcel lines, as long as they have multiple segments. The command for deleting a curve doesn't work for some reason, but you can get rid of one by deleting the PI at the beginning of the curve.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Hi Steve,
Yes. I knew about the Featureline tools. I'd just been adding PIs before I got to the curve. I did try removing the PI. However it didn't work in this case. It may have been because I was unlucky enough to end up with the curve as the closing line.
Allen
Allen Jessup
I just draw the new parcel line or convert linework then I use the parcel editing tools to delete the curve.
John Mayo
Have you then tried to add a line to the now open parcel. That's where I couldn't get any further. I could delete the curve but couldn't get a line to replace it.
Allen Jessup
Allen Jessup
I try not to leave open parcels. I add the line first which I hope creates the new parcel and then delete or f-line trim the curve which should be an extraneous parcel. Of course this depends on which side of the curve you are on. Convex, concave? 😉
Send me a file if you want.
John Mayo
Thanks John but I've already exploded the parcel and recreated it. I may try to recreate the situation as a learning exercise. The line would have been on the concave side putting the curve inside the parcel.
Allen
Allen Jessup
OK. What I did that worked (with help from johnm) was to trace over the arc, use the line and the new
arc to create a new parcel then delete the 2 common sub-entities between the parcels, the arcs. The parcels will merge. I tried Parcel Union but it didn't work.
Allen Jessup
Allen Jessup
