Civil 3D Forum
Storm Structure Table Style
2 REPLIES 2
jahunt05
583 Views, 2 Replies
I have set up a table style to display the type of structure, top of casting, and invert in and out elevations. I have also added a column to display the depth (rim to sump height). When the structure is a headwall, no depth is needed; however, the table displays this data as "???". Is there a way to only show depths greater than zero within the table editor for rim to sump height?
2 REPLIES 2
in reply to: jahunt05
you might be able to build an expression that shrinks the text really small when a certain condition exists therefore making it look as if it's not there.
Also if only 1 or 2 structures have the question marks why not just use a wipeout to cover them.
BrianHailey
Unfortunately, you can't use an expression for the height of the text within a table. It works just fine within a label style, just won't work for a table. You can use the expression within the table however. I was hoping an expression like IF({Rim to Sump Height},{Rim to Sump Height},-1) and simply tell the text component to hide negative values but that doesn't seem to work. It seems that if there is no {Rim to Sump Height} it simply returns ??? if that value is ever querried.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Rail Community
