Civil 3D Forum
Storm Structure Rotates Automatically
1 REPLY 1
rcallison
323 Views, 1 Reply
I have an issue with headwalls rotating.  When I rotate the headwall structure to 90 degrees from the pipe, the structure rotates back automatically.  Is there a way to lock the position of the structure?
1 REPLY 1
MikeEvansUK
in reply to: rcallison
Appears to be a known but with the style, the structure resets in the style (Plan view only) when edited. The actual rotation definition does not change.
The only current fix / workaround is to change the style to show the 3D object in plan view then the structure will not rotate.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Rail Community
